exact measurement
Rich
03-16-2004 05:31:38
What is the correct way to measure a plow if 2-14 or 2-16? Thanks
Hugh MacKay
03-17-2004 05:17:37
 Re: exact measurement in reply to Rich, 03-16-2004 05:31:38
Rich: The very best and sure way using a carpenter's 2' square is measure perpendicular from one landside to the next. Precission is not necessary here as most plows are either 10, 11, 12, 14, 16 or 18 inch. As riverbend states there are a few plows out there that can decieve you. On most if not all IH plows you can just measure from one beam to the next on top of plow. The plows with offset beams are quite obvious, plus most of them have different color paint.
Bob
03-16-2004 06:42:43
Measure PERPENDICULAR across the plow, from the center of one plow beam to the center of the other plow beam.
riverbend
03-16-2004 10:05:57
 Re: Re: exact measurement in reply to Bob, 03-16-2004 06:42:43
Some JD plows (44s) had offset shanks, so you will have to add or subtract that from the beam measurement.
