Axle bracket indents
Les...fortunate
03-16-2004 17:31:22
Are they the same distance apart on an M as on an H?
Been a while since I was on here. Thanks for your replies.
CNKS
03-16-2004 17:39:03
 Re: Axle bracket indents in reply to Les...fortunate, 03-16-2004 17:31:22
Terminology problem, what do you mean by an indent?
ScottyNY
03-16-2004 17:46:25
 Re: Re: Axle bracket indents in reply to CNKS, 03-16-2004 17:39:03
Les and I were talking about these earlier. Don't know the correct terminology, but we're referring to the notches in the axle housings that the drawbar mounting brackets bite into.
scotty
03-17-2004 05:28:58
 Re: Re: Re: Axle bracket indents in reply to ScottyNY, 03-16-2004 17:46:25
Hello ScottyNY, Have not seen you on the board lately, glad to see you back, I still refer to the printed copy of your BN project awhile back. Have a good day!
scotty
CNKS
03-16-2004 18:02:06
One step further -- the U part of the H/M drawbar will fit a C. Bought one with rear mount sickle mower attached to it.
CNKS
03-16-2004 17:44:50
Never mind, you mean the indents in the rear axle housings for the implement mounting brackets (what else would call them?), they are the same because IH intended the H&M to use some of the same implements.
E J
03-16-2004 17:35:11
yes
Les
03-16-2004 17:59:15
 Re: Re: Axle bracket indents in reply to E J, 03-16-2004 17:35:11
Thang Q one and all!
