intalling step head pistons in an (h)
Jonathan Mirgon
03-16-2004 22:55:43
I have a 42 H that was distillate , someone changed the head and it now has a 300 head, I ordered step head pistons for it, which way do the pistons install ? tallest part of the piston towards the cam side or intake/exhaust side.
Thanks for all your repli
03-17-2004 07:18:24
 Re: intalling step head pistons in an (h) in reply to Jonathan Mirgon, 03-16-2004 22:55:43
thanks for your help
riverbend
03-17-2004 06:33:56
The 'fire crater' should go on the camshaft side - same as the numbered side of the rods. The domes fit into the valve recess in the head.
Set one of the pistons on the head and see if the dome fits into the valve pocket. If that is good, it should be alright, but you will want to be sure.
Once you have the motor mostly together, you can check for interference in the motor by setting the head on the block (without the head gasket) and slowly turning the motor over by hand. If the pistons do not hit the head, they won't hit it with the gasket installed either. In theory, you only need something like 0.050" between the head and the piston. In reality, you will probably have something like 0.35"
On my H the domes measured about 20ccs and the valve recess measured around 120 ccs (my best recollection), so there should be plenty of room.
RB
03-17-2004 06:32:17
Most pistons are marked front or have an arrow on them pointing front. The dome of the piston must match so it can go into the head chamber. You can machine top of piston if it hits, it will hit the edge of the flat part of the head. I have done this more than once on an "M", should be the same procedure on the "H". With a "300" gas head you may be OK, the straight edge of the combustion chanber will be beveled.
justin
03-17-2004 06:00:19
Unfortunately you may run into a situation where you cannot use the step head pistons in the tractor due to the cylinder head. The steps on the pistons are designed for the specific cylinder head used on the model of tractor, and you may run into a situation where the piston will touch the top of the cylinder head. Take careful measurements of the pistons before you install anything, as you may have to install flat tops.
Aces
03-17-2004 05:29:01
Jonathan Take a look at the head the dome of the piston needs to go up past the step in the head or they will hit and not turn over.
JOE
03-17-2004 05:20:30
Jonathon, most pistons will have an arrow, or some other marking which should point to the front or radiator when installed.
