Farmall C running hard
DW
03-17-2004 02:23:06
This Farmall c was running good. I was mowing some pasture and it began to run hard..like mowing a tough patch of weeds. Now it runs like it is pulling hard. clutch in or out, in gear or out. It will crank easily,then immediately runs hard like pulling a load. Any ideas or suggestions as to what might be wrong will be appreciated.
Thanks.
DW
RB
03-17-2004 06:40:11
 Re: Farmall C running hard in reply to DW, 03-17-2004 02:23:06
Your touch control (hyd. system) may have went on pressure for some reason, either a valve stuck or linkage is binding. Control lever may have moved to far if it is misadjusted. Could you have moved one of the levers unknowingly?
rustyfarmall
03-17-2004 05:02:00
Did the distributor slip by any chance? It might just be timed slow.
Dave BN
03-17-2004 03:58:06
I don't understand the term "running hard". Is the engine running fast or making loud noise or what. Let us know more detail. Dave.
dw
03-18-2004 03:41:38
 Re: Re: Farmall C running hard in reply to Dave BN, 03-17-2004 03:58:06
The tractor sounds like it is pulling a heavy load. It won't run long, but cranks real easily.
Unfortunately, the tractor is some miles from here, now, so it'll be a few days before I can investigate further.
Thanks.
