F-12 with single front wheel that's a foot wide???
chris
03-17-2004 08:49:56
Has anybody ever seen an F-12 that has a single 12 inch wheel in the front. Anybody know what they used it for? Thanks for any and all info.
Chris
03-18-2004 17:56:07
 Re: F-12 with single front wheel that's a foot wid in reply to chris, 03-17-2004 08:49:56
Thanks for all of your info. Sounds like it could be original. I just needed a little help determining if it was an option or an aftermarket special. Thanks again and to all have a nice day.
Burt
03-17-2004 22:19:02
My dad had a 1935 F-12, came on steel with single front wheel. It was 10-12inches wide with a 1 1/2 x 1 1/2 angle iron strap around middle of wheel so it would not slide when turning sharp corner. I learned how to drive a tractor with it and spent many hours on it growing up.
old
03-17-2004 17:23:55
I'd love to say no but I have one in my shop that I have just started work on, I'd think it was so it didn't sink in to the ground in wet or soft conditions
gene b
03-17-2004 16:20:18
There several around where they planted in the lister rows and middlebusters soforth as there wasnt room for double front tires. Even had steel ones before rubber.
jal-SD
03-17-2004 11:43:01
Yep, #1 son has a '36 F-12 w/single front. Its an 8.50 X 10, I think. Looks like it came from the factory that way. We replaced the tire with an airplane tire as the one that came with the tractor was just a rag. The one we used came off of a Piper Cub, I think. It doesn't steer bad, but will slide in soft ground. (My $0.02 worth. jal-SD)
Bob M
03-17-2004 09:49:08
Chris - Never anything like that on an F-12. However we installed fat single fronts on a Super M, Oliver 1650 and JD 3020 when running two row mounted corn pickers. A local welder made the front "fork" assemblies then fitted them with used aircraft tires from an airport FBO. The fat tire worked great - especially in soft ground. But you HAD to have power steering!
