SWD6 starter problems
Eric
03-17-2004 14:14:19
Any help greatly apreciated, SWD6 will start 6 or more times with no problem then starter will sudenly go dead,it may throw a few sparks or some smoke from brush end of things. If i turn the cumunicator a few degrees it works perfectly well for a while before going dead again. I have tried cleaning out all inside's including comunicator and brushes but no improvment. thanks again Eric
Andy Martin
03-17-2004 17:37:22
 Re: SWD6 starter problems in reply to Eric, 03-17-2004 14:14:19
If you are pulling the starter to rotate it, it sounds like your Bendix is getting hung up in the ring gear. Next time it happend, try rocking the tractor backwards in 5th to see if the starter is stuck and rocking breaks it free. If so replace the Bendix.
