Does anybody make waterslide decals??
Butch Heilig
03-18-2004 11:00:47
If I understand correctly, the original factory applied decals on the letter series were waterslide type decals. Every single one of the currently available reproductions I've seen is printed on clear mylar with an adhesive back.
Does or did anyone make reproduction waterslide decals like the originals?
Tks!
Butch
BIG JOHN
03-18-2004 16:03:19
 Re: Does anybody make waterslide decals?? in reply to Butch Heilig, 03-18-2004 11:00:47
A friend of mine who spent his entire working life employeed by 3M showed me how to apply decals.
The mylar self adhesive decals should be applied with a water/soap solution. First clean the surface and then leave water/soap on the surface and apply the decals. The water/soap keeps them from sticking where you don't want them. When you have the decal in the exact location that you want it, use a plastic bondo applicator to squeegee the liquid from behind the decal making sure to get out any boubbles from behind the decals.
This is the only way that I know to be able to move the decal around to the exact location that you want it, otherwise it will stick the instant that it touches any surface.
GOOD LUCK
Farmallkid
03-18-2004 12:44:48
I have heard about these decals, They are a bit more $$$$ than the others but would make the tractor look alot better. try this sight they might have them.
www.batescorp.com
