H jumps out of 4th gear
s in pa
03-19-2004 07:26:34
Hello all,
Our H jumps out of 4th gear when using. All of the other gears work fine. I haven't used the old H for about 2 years because I wasn't sure what the problem was. Is the gear bad? I would like to get this fixed and rake hay with her this year, but I need 4th gear. If it is the gear, how do I replace it, and where do I get one?
Thanks,
Steve
Aces
03-19-2004 08:35:10
 Re: H jumps out of 4th gear in reply to s in pa, 03-19-2004 07:26:34
Fork could be bent but more likly the ball detent spring is bad and is not holding this would meen taking deck off to fix
MEK
03-19-2004 07:30:40
The shifting fork for that gear is probably bent. We had an old 560 that used to jump out of 5th until my Dad did something to bend the fork back.
