Order Farmall Cub Parts Online
154 Cub Lo-boy transmission problem
Rich
03-19-2004 16:14:05
I'm almost finished with a restoration from
a basket case. The transmission was the only
thing done when I bought it, supposedly rebuilt
with all new gears (have receipts for parts).
Got it started, but transmission is messed up.
The first three forward gears go in reverse,
and the reverse speed goes forward.
Story of my life... one step forward, three
steps back...
Looking at the service manual, it looks like the
large differential drive gear is on the wrong
side. It appears it can be installed on either
side.
That's all I can figure.
Any ideas? Anybody ever rebuild one of these
transmissions? I'm a backyard mechanic so could
try to fix it if I had to, but may try to sell
it as is.
Thanks for any help.
Rich with the goofy tractor in Florida
Rich
03-20-2004 23:52:29
 Re: 154 Cub Lo-boy transmission problem in reply to Rich, 03-19-2004 16:14:05
Thanks to you both for the help and advice...
only I wished you had told me I could take the
back plate off, and turn that gear around nice
and easy!
I may try to sell it as-is for $500 less than
I wanted, and if I can't sell it that way, I'll
have to fix it.
Thanks again,
Rich
George Willer
03-19-2004 17:03:10
Rich,
That's right, it can be installed either way... and in fact they often are. The Cub Cadets are installed opposite from the larger Cubs, since their reduction gear is ahead of the transmission rather than in the finals.
You'll be money ahead to correct it yourself rather than sell it at a necessary huge discount.
Or... you could get creative and build a fork lift.
George Willer
Rich
03-19-2004 18:20:14
 Re: Re: 154 Cub Lo-boy transmission problem in reply to George Willer, 03-19-2004 17:03:10
George,
I guess I could ride on the hood and
ride it backwards. 8.6 MPH 3rd gear
backwards is kinda scary to think about.
Can the gear be fixed without totally breaking it all down, or will I have
to tear it apart?
Do the final drives have to be yanked?
It looks from the diagram that the differential
case has to be split to reverse that large gear.
Rich
49 Cubber!
03-20-2004 04:33:06
 Re: Re: Re: 154 Cub Lo-boy transmission problem in reply to Rich, 03-19-2004 18:20:14
yep,shes got ot come apart,dont ask me how I know!!!!! !!!!
George Willer
03-19-2004 20:58:45
Rich,
I don't work on number series Cubs, but I do know that even on the Cadets the final axles have to be removed. Then the bearing retainers have to come out, since they are what holds the differential in place. The differential will come out through the rear cover. It takes a lot of fiddling to get it out, but it will come.
The next problem will be to set the gear clearance. You may be lucky and get it close by using the same shims on the same sides, but by the time they built the 154 I understand the tooling was very worn so the parts weren't consistent.
George Willer
