Problems with my 300U
Carl in WI
03-20-2004 07:04:02
The other day I noticed the oil pressure droped to 10 lbs. I then turned off the engine and checked the oil. Well to my suprise the oil was mixed with gas and very thin. I then did a oil change. I am figuring that the rings are bad and blowing gas into the crank case.
Carl
Michael Soldan
03-20-2004 14:06:25
 Re: Problems with my 300U in reply to Carl in WI, 03-20-2004 07:04:02
Carl have you used the tractor a lot in cold conditions this winter?, If a tractor doesn't warm up to operating temps and is started for short periods in cold weather it can have gas in the oil from choke and not burning 100%. You've changed the oil, use it for a while and check again..it just may have been the cold weather.Had an Allis once that did that in the wintertime....Mike in Exeter Ontario
dick
03-20-2004 07:37:23
Carl - are you sure it's gas? It's fairly common for the seals on the hydraulic pump to leak hydraulic fluid into the engine oil. I'd suggest you check the level in your hydraulic reservoir.
Kit Gage in VT
03-20-2004 08:40:30
 Re: Re: Problems with my 300U in reply to dick, 03-20-2004 07:37:23
Yep, that's what happened to me *NM*
