Help on SMTA water pump
Keith
03-20-2004 07:42:40
Helping a friend on SMTA water pump problem? Coolent is leaking at the front of the pulley. Does this indicate a bad seal? How difficult is it to rebuild a water pump? I have checked various sources and it seams that the cost for rebuit units range from 200 to 350 dollars. Is there a low cost solution for this problem? Thanks for any help you can provide. Keith
49 Cubber!
03-20-2004 10:09:47
 Re: Help on SMTA water pump in reply to Keith, 03-20-2004 07:42:40
Dont know on the SMTAbut if the pump is similar to the M pump,it can easily be rebuilt, Iwouldnt just put new seals in,change the bearings as well.If the impeller shaft is worn,youre beter off getting a new pump.Unless things have changed in the last couple of years,those arent available new,and I was told by someone,that good used ones were real high.I ended up buying a good used pump and rebuilding it.
Keith
03-21-2004 07:41:51
 Re: Re: Help on SMTA water pump in reply to 49 Cubber!, 03-20-2004 10:09:47
Thanks, 49 Cubber. Your information and knowledge is greatly appreciated. I've received a couple of e-mails from tractor parts companies offering re-built or new SMTA water pumps at very good prices.Thanks again for your help. Keith
