Will a 12 volt coil work on a 6 volt system
Chris Cummings
03-20-2004 19:47:26
I have a O-4 McCormick-Deering with a six volt system. I have a 12 volt battery in it with positive ground. I was wondering if a 12 volt coil will work or do I have to have a 6 volt coil.
Haas
03-21-2004 06:39:59
 Re: Will a 12 volt coil work on a 6 volt system in reply to Chris Cummings, 03-20-2004 19:47:26
If you have a battery ignition with a 12 volt battery, you will need a 12 volt coil, or you can use a resistor in series with a 6 volt coil. If you use the 6 volt coil with the 12 volt battery and no resistor, the coil will overheat and burn out pretty quick.
