Re: Throw Out Bearing-1949 Super AV
Haas
03-21-2004 06:46:03
You can reuse the original bearing. If you use the new ball bearing that came with your kit, you will also need a new clutch release bearing holder to install it. The new bearing holder will replace the casting that holds the old style bearing.
