Order Farmall Cub Parts Online
Farmall Cub stalls
joi
03-21-2004 09:03:30
My father's cub is stalling out when clutch is being engaged for both pto and driving gears. Also stalls when throttle is adjusted. I suspect that the governor may be the culprit. However, I have never had to make an adjustment to the governor before. Can anyone tell me how the governor is adjusted? And if this sounds like a problem unrelated to the governor, please share your advice. Tractor has new plugs, rebuilt carb (no leaks) and clean fuel lines.
Bus Driver
03-22-2004 04:57:15
 Re: Farmall Cub stalls in reply to joi, 03-21-2004 09:03:30
It is likely that the high speed jet is partially clogged. Unless something breaks, governors do not suddenly readjust themselves. The high speed jet is the brass 3/8" hex on the side of the carburetor. Just remove it with a wrench. The critical hole is the one in the end of the threaded portion. Clean that hole with smooth wire and compressed air- do it several times. Do not change the size or shape of that hole. A 5 minute job.
Bigdog
03-21-2004 09:57:05
Take this link to the service manual page. The actual governor linkage adjustment procedure starts on page 2-18.
