460D stuck in reverse!
Gary in MOzarks
03-21-2004 10:19:20
I was spreading gravel this morning with our 460D on a slight incline. When I tried to put it in reverse it didn't want to move. I keep fooling with it and eventually got it into reverse but letting out the clutch killed the engine. I discoverd that the transmission is in reverse when the shifter is in netural and putting it in any other gear kills the engine. Help What did I do, and what do I do now? Thanks
Aces
03-21-2004 10:33:04
 Re: 460D stuck in reverse! in reply to Gary in MOzarks , 03-21-2004 10:19:20
Gary I would say the lower end of the shift lever is warn off and needs repair or replace. just take the 3 cap screws out of the tower and remove. Set the brakes disengage the clutch and you should be able to use a bar or screw driver to line up the notchs in the rails. After you fix shifter adjust you clutchs.
Gary in MOzarks
03-22-2004 13:40:08
 Re: Re: 460D stuck in reverse! in reply to Aces, 03-21-2004 10:33:04
Just wanted to let you know that I did what you said and you were right! Thank you Gary
Gary in MOzarks
03-21-2004 12:24:05
Thanks ACE that makes sense, The clutch has been at the bottom for a while and I have put off adjusting it. Now I will have to do that. Thanks again G
