Where is HYDRAULIC fill plug on Farmall 240?????
LJS
03-21-2004 13:52:02
My Farmall 240 leaks a little fluid from hyd.
valves. I would like to flush system and put
new fluid in, BUT I can't find fill plug.
Please help. Is it the plug located on torque
tube?? Also where do you check fluid level at???
rex
03-22-2004 03:43:39
 Re: Where is HYDRAULIC fill plug on Farmall 240??? in reply to LJS, 03-21-2004 13:52:02
Look for the plug just ahead of your hydro valves under the gas tank its the only plug that is horizontal on the clutch housing I think its about 1" or a little bigger but I use an adjustable wrench on it but its a tight fit I fill mine up to the point when I can stick my finger in the hole a just get the end of it wet. Rex
