Coil Prob Solved
Denny
03-21-2004 16:29:17
After 2 days and many new parts, I found I had the firing order backwards on the dist cap. Got the rotation wrong. As with anything guys, check the obvious again and again!! Denny In MI.
Hugh MacKay
03-21-2004 18:11:42
 Re: Coil Prob Solved in reply to Denny, 03-21-2004 16:29:17
Denny: Did that one myself once, after installing a new clutch in my 130. Got in a hurry to finish the job. One thing I've learned over the years, is a farmer doing mechanic work should take his time. It is faster in thr long run.
Jeff in Ontario
03-21-2004 18:03:19
So true.. the obvious things are often the easiest to overlook! Glad to hear that you got it figured out! --Jeff
