Farmall Exhaust Lift
David
03-22-2004 18:50:22
I just bought an exhaust lift and was wondering how it should be mounted. If someone has some pictures they could email me that would be great. Thanks.
BillWV
03-24-2004 04:54:21
 Re: Farmall Exhaust Lift in reply to David , 03-22-2004 18:50:22
third party image
Here is a pic of my A before restoration. I removed the exhaust lift and all of the other attachment brackets. Probably never to install them again. The exhaust lift would pick up a mid mounted scraper blade...on a good day.
Bill
gene b
03-23-2004 17:23:12
The cyclinder is mounted in several different positions depending on which implement you are using it on. The rest of the unit is mounted on the engine along with the linkage. I have four of them that i use on different implements. I have used these systems since 48 and have parts.
scotty
03-23-2004 08:14:46
third party image
Here is a picture I found in the archives.
scotty
Bob
03-23-2004 06:34:46
What's an "exhaust lift"? Funny images are running through my mind.....
DENNIS in NC
03-23-2004 04:59:25
whats it going on, i have a 39 farmall B with lift and witch way are you going to mount it vertical / horizontal
Sid
03-23-2004 03:27:09
I can e-mail an Owners Manual if you want. Sid.
DENNIS in NC
03-23-2004 15:01:15
 Re: Re: Farmall Exhaust Lift in reply to Sid, 03-23-2004 03:27:09
sid send me a copy of that so i can see if it is the same as mine
Sid
03-24-2004 03:23:11
 Re: Re: Re: Farmall Exhaust Lift in reply to DENNIS in NC, 03-23-2004 15:01:15
Dennis, send me your e-mail address so that I can reply, Sid.
John *.?-!.* cub owner
03-23-2004 06:10:49
Sid, I have a friend that has an exhaust lift, and I would appreciate it if you could also email a copy to me
Thanks
ejpuckett@centurytel.net
