MW Hand Clutch and 9-speed
Rob
03-22-2004 23:30:29
Hi there! I have two fairly "unique" Farmalls. I have a 1950 M with the M&W Hand clutch and an H with the 9-speed and Live Hydraulic Pump. how common are these options. Is it rare to have an M with the Hand Clutch or an H with a 9-speed Trans? How many of these are out there? Thanks for any info!
-Rob Bush
Wardner
03-23-2004 00:44:35
 Re: MW Hand Clutch and 9-speed in reply to Rob, 03-22-2004 23:30:29
It can be done the other way around too. On top of that you can put both the 9 speed and the hand clutch/live PTO on the same tractor whether it be a H or M. I have already done it.
Those after market items are not that rare. Thousands were sold and can still be found by those looking for them.
However, after having said that, I don't recall seeing either accessory at the Red Power Round Up last year. There were probably at least 100 H's and M's there.
David
03-24-2004 20:06:11
 Re: Re: MW Hand Clutch and 9-speed in reply to Wardner, 03-23-2004 00:44:35
I have a good idea with how the hand clutch works. How do you go about "converting" one to 9 speed. That sounds like a pretty big deal.
TP from Central PA
03-23-2004 03:39:13
I didn't see any either, but you could tell that most of them were from the northeast..... .....Their was ALOT of side hill hitche setups there!
Wild Horses
03-23-2004 10:30:57
 Re: Re: Re: MW Hand Clutch and 9-speed in reply to TP from Central PA, 03-23-2004 03:39:13
We have an M with both, plus the original wide front. Maybe I'll have to get it running and bring it down to the show in June. The hand clutch is handy for pull starting someone or winning slow races.
Red Dave
03-23-2004 06:39:41
There sure were.
And one guy with a JD T-shirt ;^)
TP from Central PA
03-23-2004 06:48:42
 Re: Re: Re: Re: MW Hand Clutch and 9-speed in reply to Red Dave, 03-23-2004 06:39:41
Are you serious..... ..... Some ACTUALLY DID THAT!(Grin)
