super A body work
mikeinWA
03-23-2004 08:55:40
I am really getting close to having this gem back together. I have two questions:
Any suggestions on aligning the tin? It looks pretty good but I could close the gap where the hood meets the tank and the grill. I am guessing there is no easy way and I will have to continue to tweek the different components here and there.
What Dupont color for the silver of the wheels?
Dave
03-23-2004 17:07:05
 Re: super A body work in reply to mikeinWA, 03-23-2004 08:55:40
I've used a GM Paint Code 13, Bright Silver Poly, the PPG Code is MAE3822 A, and it looks the best I've seen.....
scotty
03-23-2004 09:47:09
Mike, If your hood has the J-hook fasteners they are spring loaded and should pull the hood down on top of the front of the gas tank using the tabs welded on the tank. The same thing with the front but you will be latching on the radiator supports. As for the paint, I use rustoleum aluminum and I think they look good.
scotty
