Junk 230 fast hitch ?
Andy in Ohio
03-23-2004 11:23:32
I picked up an IH 230 that is locked up. It has a fast hitch onit. ?, will it fit on a Super C or a Straight C without any problems? And is it worth switching? TKhe tractor is for parts so I cant use it on this one, but I am eventually going to get a C' or SC'. One more ? while Im at it. Will the wide front on the 230 also fit onto a C'? Thanks for the replies, Andy
Stan(VA).
03-23-2004 14:25:38
 Re: Junk 230 fast hitch ? in reply to Andy in Ohio, 03-23-2004 11:23:32
The wide front will interchange through the different models, but not the fast hitch. The Super C/200 fast hitch will work back to the C; the 230 hitch is a new design and requires a different tranny housing with the extra mounting boss underneath. It will go on the row crop 240 though.
Stan(VA).
Andy in Ohio
03-23-2004 14:55:22
 Re: Re: Junk 230 fast hitch ? in reply to Stan(VA)., 03-23-2004 14:25:38
Stan, Will a SC engine interchange into a 230. Also, what are the fast hitches on these models worth in case I can't find an engine? Thanks, Andy
Stan(VA).
03-23-2004 19:52:57
 Re: Re: Re: Junk 230 fast hitch ? in reply to Andy in Ohio, 03-23-2004 14:55:22
Yes, the Super C or 200 motor will fit, just down a little on power. Value on the hitches is subjective as you would guess; based on condition I've seen asking prices from $100 to $500. If you part tractors, then it isn't an issue. But if you need a Super C type machine, (and the 230 is clean other than the stuck block) it would be a very handy small tractor to have around.
Stan(VA).
Stan(VA).
03-23-2004 20:04:01
 Re: Re: Re: Re: Junk 230 fast hitch ? in reply to Stan(VA)., 03-23-2004 19:52:57
Andy,
Didn't think of it before, but I have an extra Super C motor with the standard repaired water jacket. Other than that, it's a complete running motor for $400. Might be a cheap way to make it useful. Let me know if interested. srbheadlight @ yahoo.
Stan(VA).
Gary_N_WV
03-23-2004 15:46:11
Andy, I'm looking for a wide front...wanna part with it?
I'm gonna be in Ohio this weekend.
I have enabled my e mail !
Gary
Andy in Ohio
03-23-2004 18:42:12
 Re: Re: Re: Re: Junk 230 fast hitch ? in reply to Gary_N_WV, 03-23-2004 15:46:11
Gary, I may just do that. I took it off today in hopes that some day I would find a nice SC to put it on. Make me an offer I cant refuse and you may own it! Thank you, Andy
Gary_N_WV
03-23-2004 18:59:07
 Re: Re: Re: Re: Re: Junk 230 fast hitch ? in reply to Andy in Ohio, 03-23-2004 18:42:12
email me andy...Ill answer your message tomorrow...I gotta get off here for now.
email is enabled.
thanks !
Gary
