3-point not lifting properly
Todd Mealy
03-23-2004 19:46:24
I have a 2404 that will lift the 3-pt arms when the tractor is first started, but if you let them down a little and try to go back up it will not lift. Sometimes if you let it go ALL the way down it may lift but it is very slow with response.
jack
07-13-2004 10:03:52
 Re: 3-point not lifting properly in reply to Todd Mealy, 03-23-2004 19:46:24
Todd, make sure that the hydraulic system doesn't have air in it. Have you taken the filter apart, cleaned the screen, and replaced the element? Does your power steering work OK? There is a priority valve which directs output from the pump to the PS system first, then the 3 point. These valves can wear out, according to what I have heard. I have a 2404 that I got recently. At first, neither the 3 point or the power steering worked, now the 3 point is working good, but the power steering is not yet working all the time. Good luck with you lift problem- Jack
