stay rod ball diameters needed
Val
03-24-2004 10:30:38
Can anyone tell me if the ball diameter of the stay rod ball at the back of the wish-bone on a 560 is the same as the ball on a 886. I know the 886 has a threaded end on the ball vs the weld in style on the 560, but if the ball diameters are the same I can make it work instead of spending $88. Thanks.
Jim J
03-24-2004 13:51:55
 Re: stay rod ball diameters needed in reply to Val, 03-24-2004 10:30:38
I use the late type ball in the early wide fronts. You will have to enlarge the hole a little. I have a new ball for $25.00.
