M clutch and pressure plate ?
TL
03-24-2004 17:07:58
I just put in a new clutch and pressure plate in our Farmall M.The trouble is I have about 3/4 inch of freeplay then good clutch pedal but it grinds and won't let it go into gear.I am not sure what to do.Any help would be greatly appreciated.
Jim
03-25-2004 08:20:17
 Re: M clutch and pressure plate ? in reply to TL, 03-24-2004 17:07:58
You could have badly worn pedal shaft, pedals and /or linkage. These do wear badly and they are critical to getting the necessary travel to getting release and the clutch disengaging. Been there recently. Let us know what ends up being the solution. I am sure you will find it. Be happy it is a M not a Super M where the tractor must be split.
Bob K
03-26-2004 12:58:35
 Re: Re: M clutch and pressure plate ? in reply to Jim, 03-25-2004 08:20:17
I'm with Jim on this one. The pedal linkages are so worn on my 450 that I can only have "positive" clearance between the clutch fingers and the throwout bearing - not the recommended 3/16" gap. Otherwise, the clutch would not disengage so I could change gears. The gap is less than spec, but everything works.
MN Charlie
03-25-2004 10:36:20
Some of those pedals and shafts really get woren. I'm thinking about setting up a jig on my bridgeport milling machine to machine those pedals out and install a bushing that would fit a new shaft properly. Would this be something that there is a need for? MN charlie
CNKS
03-25-2004 19:49:43
 Re: Re: Re: M clutch and pressure plate ? in reply to MN Charlie, 03-25-2004 10:36:20
There is a need for it, but any machine shop can do it, had the clutch and one brake pedal done locally last year. OEM Tractor Parts, and others will do it also -- but, if you could do it cheaper and start a price war, that would be welcome.
Jim
03-25-2004 12:40:21
I think there would be a need and it will get greater as these machines get older.
Val
03-25-2004 04:32:27
Possibly the clutch disc in backwards??
TDK
03-24-2004 18:54:42
TL, Could be any of the problems mentioned by yourself or Haas. I learned the hard way not to assume replacement pressure plate fingers are set correctly from rebuilder or factory. Won't hurt to check it.
Haas
03-24-2004 18:38:16
Did you replace the throwout (clutch release) bearing and the pilot bearing. Sounds like the clutch is not releasing or these bearings are dragging. Also, if the clutch splines are worn or damaged, the clutch disk may not slide back like it is supposed to do.
TL
03-24-2004 18:46:01
 Re: Re: M clutch and pressure plate ? in reply to Haas, 03-24-2004 18:38:16
Yes, I replaced the throwout bearing and pilot.I put the pressure plate in just as it was from the dealer.Since I didn't measure the pressure plate cover height or lever height,I am wondering if this is my problem.
Haas
03-25-2004 05:25:58
 Re: Re: Re: M clutch and pressure plate ? in reply to TL, 03-24-2004 18:46:01
As Val said, are you sure you did not put the clutch disc plate in backwards? If you did that, the ring on the plate will keep the clutch from disengaging. However, in that case, I would not think you would have the free pedal travel you say you have.
