w6 Gas Tank
Bill Newton
03-24-2004 18:34:50
Does the hood for a W6 attach to the gas tank the same as on an M? I have an M tank on my W6, but there doesn't seem to be any place for the J spring to attach to the tank. Does the tank have to be from a W6? Thanks.
Bill
Paul in Mich
03-25-2004 16:24:48
 Re: w6 Gas Tank in reply to Bill Newton, 03-24-2004 18:34:50
Bill, An M gas tank should work just fine on your W6. The rear "J hook" mechanism is the same for both tractors.
MN Charlie
03-25-2004 10:28:03
I just went and looked at the W-6 gas that I just found this winter, I'm trying to make it run, it has sat in a shed for over 10 years that I know about and maybe even longer. The engine turns and the fuel tank is dry no rust or varnish. I see that I will need to find a "better" rear rim.
I went and looked at the fuel tank and it's made just like an M with the hooks welded on the front for the J hooks to catch on. I hope this helps, good luck.
MN charlie
Wild Horses
03-25-2004 05:32:07
We swapped out the original tank on my W6 with an NOS M tank. The rear hook catchs on a metal bracket that is welded in the corner of the tank just below the seam.
Bill Newton
03-25-2004 20:00:42
 Re: Re: w6 Gas Tank in reply to Wild Horses, 03-25-2004 05:32:07
Thanks for the responses. My hooks are about an inch in front of the bracket on the tank. The bracket wraps around the corner of the tank and has a diagonal slot on the side facing the radiator. Should there be anything protruding from the bracket for the hook to attach to? I may have to find an M or W6 to look at. Thanks again.
Bill
Wild Horses
03-26-2004 08:17:05
 Re: Re: Re: w6 Gas Tank in reply to Bill Newton, 03-25-2004 20:00:42
Just going to memory here, but there should be a small hooked tab that comes off that bracket. I believe it was all one piece & bent out 90 deg
from the bracket and then bent 90 deg again the form a hook. If it's broken off, there should still be a triangular hole in the front of the bracket from where it was stamped out.
Bill
03-26-2004 09:35:19
 Re: Re: Re: Re: w6 Gas Tank in reply to Wild Horses, 03-26-2004 08:17:05
Thanks. I guess that's what's missing.
Bill
