Farmall H Belly Pump
Ryan George
03-24-2004 20:57:02
i pulled the belly pump to re route the return line from my live hydraulic pump directly into the belly pump. however, when i pulled the "pump" it turns out someone had already gotten rid of the pump and put a resevoir in it's place. there are no other pipe fitting on the resevoir than the breather tube outlet, live pump feed, and drain plug. i am considering drilling a hole in the plate that bolts on the side of the resevoir and welding a pipe fitting in the plate to return oil from a control valve. any comments or other suggestions are welcome. also, will returning the fluid to a lower spot on the resevoir eliminate my problem of oil coming out of the breather tube? ( oil used to be returned about an inch or two below the breather tube)
Thanks!
Ryan George
03-25-2004 10:06:03
 Re: Farmall H Belly Pump in reply to Ryan George, 03-24-2004 20:57:02
will the drain plug be large enough for the volume of oil returning to the resevoir? it's only 1/2 inch and i would like it to be 3/4 or so.
Wayne Swenson
03-25-2004 05:45:05
Why not return the oil to the drain plug at the bottom of the casting. You can put a "tee" fitting in and still have a drain as well.
Nebraska Cowman
03-25-2004 04:30:24
use the drain plug hole, you can dump the return in the top.
Old Farmall
03-25-2004 20:03:28
 Re: Re: Farmall H Belly Pump in reply to Nebraska Cowman, 03-25-2004 04:30:24
If there is a hole in your breather cap, drill and tap it for a plug so it doesn't leak! If your tractor had a 2 way hydraulic system on it from the factory, this filler cap will have a small valve where the breather hole would be. Make sure it is shut off when using 2 way cylinders. Open the valve when using 1 way cylinders. If you don't plan on using 1 way cylinders, just plug the hole as I mentioned above. See your LATE Farmall H or Super H tractor manual that shows the 2 way hydraulic system for the details. (With 2 way cylinders you don't need a breather because the oil never leaves the system - unless you have a bad leak!) Good Luck!
