To Scott TN RE: Carter Float Setting
FC
03-25-2004 06:14:12
Scott, the manual calls for the float on the Carter carb to be set as follows:
Top of float 11/64 inch +- 1/64 below top surface of upper body casting. If memory serves correctly this roughly translates to "level" when float is against needle valve. If you would like to post your email I can email you a copy of the manual of the Carter UT in pdf format. Hope this helps...
Scott TN
03-29-2004 11:05:23
 Re: To Scott TN RE: Carter Float Setting in reply to FC, 03-25-2004 06:14:12
Hi, Thanks for the carb float info!! I ordered a basic carb kit and will install this week. If you can email the section out of your manual it would be greatly appreciated. My email is sfricker@gm.com. Thank you very much for you help!! Scott
PGNS
03-25-2004 06:21:15
FC: I hate to be nosey but I am currently refitting my Carter UT carb and I would any information about setting the floats or anything for that matter that will help me with my carb. I do not have a manual for the the carb except for the info in the parts manual. I would really appreciate any info for my carb. Thanks from Nova Scotia way!
FC
03-25-2004 07:58:24
 Re: Re: To Scott TN RE: Carter Float Setting in reply to PGNS, 03-25-2004 06:21:15
I can email what I have if you don't mind posting your email address. I understand if you don't wish to as I know there have been spam issues with doing so.
PGNS
03-26-2004 12:28:45
 Re: Re: Re: To Scott TN RE: Carter Float Setting in reply to FC, 03-25-2004 07:58:24
My email address is : PGNS_7@hotmail.com. Thanks in advance!
