C parts hunt, found em all! heres the list!
Tommy H
03-25-2004 14:08:40
Well, after an exhasting search, ive found every part I need to complete the C project.
1. Shift knob-5.00
2. Rear bullet style combo light- 87.00
3. (2) brake bands, with linings- 65.00
4. Radiator cap with lever- 20.00
5. Spark plug wire set- 8.15
6. Magneto-USED-TESTED/FUNCTIONAL-125.00
7. (2) Headlights, complete bullet style-100.00
8. Cylinder head gasket set-17.25
9. Exhaust pipe- 8.00
10. Manifold assembly- 92.00
11. muffler, original style, correct sound-21.65
12. Muffler clamp- 7.20
13. Ammeter- Correct look- 25.25
14. Instrument panel, Used, no rust!-17.00
15. Belt pulley guard, used, no rust!- 22.00
16. PTO sheild-45.00
17. Seat spring-11.00
18. Shock absorber-35.00
19. Battery Box (1 peice)-67.00
20. Battery Box Cover-47.00
21. Temo Gauge- 64.00
22. Oil Gauge-34.00
23. Upper air cleaner Hose/Both Radiator hoses-13.50
24. Prebent Metal Fuel line- 17.00
25. Generator Belt- 11.00
26. Starter Switch- 15.00
27. Carb Kit for Zenith Carb, complete rebuild- 28.00
28. Tool Box- 94.00
29. Seat pan- 94.00
30. Seat hinge bracket- 30.00 Used, good shape
31. Headlight Harness 11.25
32. Main Harness- 23.50
33. Ignition Harness- 18.00
$1,225 shipped!
That completes the tractor, except for tear down, rust removal, sanding, priming, and painting.
now all I need is money..lol
CNKS
03-25-2004 18:54:58
 Re: C parts hunt, found em all! heres the list! in reply to Tommy H, 03-25-2004 14:08:40
If you want an OEM type muffler, like the one that came on your tractor with the original sound, they cost $79 (Mark's Tractors 217-694-4735), the $21.75 one does not have the correct sound and may discolor the first time you run the tractor. They do not last very long, but don't cost much either. The $79 mufflers were made with IH blueprints and are correct. The only one better is a NOS one, if you can find it. The head gasket sounds a little cheap. Those things are hard to seal, that's one item you that you should bite the bullet and get from Case-IH. Seat spring seems about 1/2 price -- new? A used one is apt to be too soft. If you want to stop or prevent leaks, you should get new seals for the axles, pto, hyd pump, brakes, etc, etc. If you paint an old tractor, you will begin finding leaks you didn't know existed, about the time the paint dries ---- Good Luck!
Tommy H
03-25-2004 20:13:22
 Re: Re: C parts hunt, found em all! heres the lis in reply to CNKS, 03-25-2004 18:54:58
Its mostly all new, the spring is used, but in excellent shape with no rusting at all, apparently, installed but tractor was quickly dismantled.
The gasket set is just a head gasket, water neck gasket, and manifold gasket.
The PTO Housing, and PTO shaft, and Belt Pulley all need new seals, but those are cheap im sure.
The hydraulic system appears to be fine, no leaks at all, and Ive checked everywhere. Ill try and find a price on a gasket set for the hydraulic system.
CNKS
03-25-2004 20:21:25
 Re: Re: Re: C parts hunt, found em all! heres the in reply to Tommy H, 03-25-2004 20:13:22
Be sure that the pump is not leaking hyd fluid into the crankcase. This is a common problem and sneaks up on you. Pull the pump and replace the seal, if the shaft has a groove, you need a speedi sleeve. If the seal is an o-ring, and there is a groove, you have to have the shaft hole enlarged to accept a speedi sleeve. Seals are one item that is overpriced at your Case-IH dealer. A good bearing shop can cross reference or match most of them at 1/2, 2/3's the IH price. Same seal, same brand.
