repowering Farmall H with International truck engi
Jonathan
03-25-2004 16:41:02
Hi, I have heard of people putting an International V8 truck engine in Farmall M's, and I was wondering if I could possibly do it to an H?. I don't think this is the route I'm going to go, but I thought I would look into it.
thanks
Buzzman72
03-26-2004 06:58:29
 Re: repowering Farmall H with International truck in reply to Jonathan, 03-25-2004 16:41:02
See the post above about 6-cylinder M's; then go to the Tractor Pulling forum and see the post about the truck engine (345), and then check out ChadS's 460H. I think that, under the torque of the V8's, the H transmission would be your safety valve; in other words, I think you'd probably damage the transmission before you got into other serious trouble because of the power.
But that's just my opinion, and there are a lot of wiser and more experienced folks here than I.
Jonathan
03-26-2004 19:12:35
 Re: Re: repowering Farmall H with International tr in reply to Buzzman72, 03-26-2004 06:58:29
thanks!, I'll check that out.
r4etired
03-26-2004 19:01:05
Unless you widen the frame rails, You will be getting into the oil galley when you cut the 345 block. It is real close when you put them in an M
