SMTA clutch
Farmer Dan
03-26-2004 07:15:08
I pulled the engine on my A recently and noticed the splines on the clutch pressure plate are badly worn. These are the ones that run the live PTO. Got a new pressure plate on the way but is this a common problem on them? Is the same pressure plate and pto drive mechanism used on number series also?
Aces
03-26-2004 10:12:37
 Re: SMTA clutch in reply to Farmer Dan, 03-26-2004 07:15:08
Dan on a SMTA I would think it would take years for the splines to go bad. That could be the same spline as 560.
