Hydraulics On 656
Darin
03-26-2004 09:09:44
Purchased a 656G a year ago to bale some small squares, but now decided to see about purchasing a round baler. Problem is my tractor only has 2 svc ports and need 4 to run big baler, is it possible to convert hydraulics from 2 to 4 ports (I have no clue)and is it even cost effective to consider.If it is can someone give me a ballpark idea of price and what all it takes to convert. Any and all help greatly appreciated.
E J
03-27-2004 11:14:09
 Re: Hydraulics On 656 in reply to Darin, 03-26-2004 09:09:44
Go to a salvage yard and buy one or two extra spools off a 656 just stack them on your existing valves with longer bolts and levers use your own end cap.
Darin
03-27-2004 20:44:45
 Re: Re: Hydraulics On 656 in reply to E J, 03-27-2004 11:14:09
Thanks for the idea about the salvage yard,that sounds like a much better idea than going to our local implement dealer to check their prices. Might be able to talk to one of the mechanics and get the labor done cheaper too.Thats the reason I put this question on here, you get so many good opinions that you might not think of without years of expierience and lots of time and money wasted.Keep the good ideas coming.
ny bill
03-27-2004 04:57:11
a few suggestions:
there should be a ton of those valves in wrecking yards for much less than a new setup.
V&M (maybe others) makes a kit with solenoid switches that plugs into the single remotes and gives you dual remotes. i round bale with my 826 hydro, and i've had a set on it for 4 years and only had to replace the $5 thumb switch once. i've seen the kits at my ih dealers'.
if you want to go really cheap, get a 2 way divert valve from northern and plumb that into the system. my dad has one on his 806 for the plow and gets along well with it.
Dan
03-26-2004 12:40:23
By 2 ports I am assuming you have only one valve or circuit is that correct. I would think you could get an open cneter, 2 spool valve and run hoses from your valve through the new one. Would then just tie current valve handle in engaged position, and use the 2 spool valve. I imagine you might find the original type but probably spendy.
JB
03-26-2004 19:07:10
 Re: Re: Hydraulics On 656 in reply to Dan, 03-26-2004 12:40:23
Hi, I know the kit was available from IH about 12 years ago as neighbor had 656D and bought a NH harvester tha required two remotes and he only had one, so he purchased additional one from IH but it was in the order of $300.
JB
Darin
03-26-2004 19:58:44
 Re: Re: Re: Hydraulics On 656 in reply to JB, 03-26-2004 19:07:10
Thank You for your ideas, I plan on looking into both of your ideas to see which would be best for my situation. Thanks again.
