706 hydraulics
nate
03-26-2004 18:12:07
i am going to hook up to my buddies post pounder to drive some fence posts at my place. Ive got a 706 with a three point. The pounder gets its power from one side of a remote valve, tied open, and is controled by a valve on the back of the pounder. when i pull that valve to drop the hammer i need to get fluid out if the cylinder fast. on his tractor (7600 ford) he has a one inch line going to his hydraulic breather/fill on the top back of his hydraulic unit. is there any place on a 706 besides the fill hole in the platform where there is a big enough hole to get an inch hose hooked into it somehow.sorry for the length, thanks
nate
the tractor vet
03-27-2004 12:24:49
 Re: 706 hydraulics in reply to nate, 03-26-2004 18:12:07
Pull the transmission dip stick out and put someplace that you won't loose it and put the return line in there and tie it down so it won't blow out. Oh also DO NOT REMOVE THE DIP STICK WHILE THE ENGINE IS RUNNING OT TRY TO PUT IT BACK IN WITH THE ENGINE RUNNING as it can get into the transmission gears .
nate
03-28-2004 14:00:01
 Re: Re: 706 hydraulics in reply to the tractor vet, 03-27-2004 12:24:49
thanks for the info, that is what ill do.
nate
