My super M won't start
Griz
03-27-2004 09:11:40
It's been about 6 weeks since I started my Super M and now it won't start. The gas is on, the kill switch is out and it turns over fine but no fire. There is plenty of gas as well. I hooked up my battery charger and even with that it still won't start. It acts like it is not getting any gas. Any suggestons?
Griz
r4etired
03-27-2004 16:23:37
 Re: My super M won't start in reply to Griz, 03-27-2004 09:11:40
My super had not been started since about Christmas.I had the same problem turn over good but not start. Removed the dist cap the rotor was coated with a white coating. replaced it. It would run on two cyl. replaced the cap and it ran fine. I had just replaced the points and condenser last fall. I would pull a plug and see if your getting fuel
Delbert
03-27-2004 12:21:32
If it has been converted to 12 volt check your resistor. Check to see if you are getting fire through your points to the spark plugs.
Bigdog
03-27-2004 09:48:37
Pull off a plug wire and see if you're getting spark. If it's set for 6 weeks, it could be points glazed over or carb float or needle valve stuck.
