Brakes on WD 6
FredWi
03-27-2004 12:17:20
Hi, I replaced the band on the one side but how do you go about replacing the one that the steering linkage is running right along side the brake cover? What or how do you get the linkage out of the way? I have a couple manuals but they don't tell me anything. Thks, FredWi
Geoff NY
03-27-2004 16:06:35
 Re: Brakes on WD 6 in reply to FredWi, 03-27-2004 12:17:20
Disconnect the steering linkage at the rear of the drag link. iIt will drop out of the way, then turn the steering wheel all the way to the stop and it should clear. good luck
FredWi
03-27-2004 16:18:17
 Re: Re: Brakes on WD 6 in reply to Geoff NY, 03-27-2004 16:06:35
GeoffNY thanks for the info. I did take the nut off the bolt last night and put some WD 40 on it to soak---but I'm not real sure if the bolt has enough room to come out before I hit the brake casing. I will try and let you know if I get it. Thks again. FredWI
