Order Farmall Cub Parts Online
Cub cadet pto clutch
lonnie
03-27-2004 14:49:13
how does the pto clutch come off of a k241 model 100 cub cadet? thanks
Harold H
03-27-2004 16:02:02
 Re: Cub cadet pto clutch in reply to lonnie, 03-27-2004 14:49:13
Remove the three setscrews around the clutch, these are just the locking setscrews. Then remove the three setscrews that are under the three setscrews you just removed. The entire clutch will now come off. (Before you start, line the three cutouts on the corrigated shaped part of the clutch over the three setscrew locations).
Harold H
Blair Conlkey
08-31-2004 18:44:00
 Re: Re: Cub cadet pto clutch in reply to Harold H, 03-27-2004 16:02:02
I am working on a Model 129 PTO Clutch rebuild.
I found the three allen screws in the PTO pulley itself very difficult to turn. One seems to be damaged, and will not turn at all. Any information you can share would be of help:
What size allen wrench(es) are required?
Are the locking setscrews and the actual setscrews the same size?
Any suggestions for the damaged setscrew removal?
What is the procedure to remove the pulley (and will the clutch assembly come with it)?
I appreciate any information.
