Super C Fast Hitch Questions
Bud
03-27-2004 17:39:46
#1 I need to reinstall the check valve in front of the seat. I need the hose routing.
#2 How much hydraulic oil will leak out when I disconnect the hoses? I was planning to block up the hitch so it can't fall.
#3 What kind of hydraulic oil should I be using?
#4 One of the pistons is seeping oil on the unit under the gas tank. I hate to pull the unit but will if I must. My question is will the leak stop once the level drops below the piston seal and if so will there still be enough oil in the tank to operate the rear hitch. I never use the front lifts anyway.
Thanks
CNKS
03-27-2004 19:26:32
 Re: Super C Fast Hitch Questions in reply to Bud, 03-27-2004 17:39:46
#1 I don't have fast hitch, so I don't know the hose routing, if that's what you asked.
#2 Not a whole lot, be careful when you take off the hoses, as there might still be pressure.
#3 Case-IH Hytran or hyd oil that meets Hytran specs.
#4 It will continue to leak. It is possible, but not easy to replace the seal with the reservoir on the tractor -- I would remove the reservoir and put a gasket and seal kit in it -- About $90.
