3 Point hitch on H
Farmall Ed
03-27-2004 18:28:00
I have been rigging up a 3 point hitch on my H and I now have it working very well except for a leaking cylinder. I took the cylinder apart and put in new seals one flat seal and an O ring in two places, but it still leaks. When I took it apart one of the flat seals was riding up out of the groove so I thought new seals would fix it. After about three cycles it leaked again. Any ideas why I am having this problem,Is there a secret to installing these seals ? Any help will be appreciated. ED
Road Warrior
03-27-2004 19:11:09
 Re: 3 Point hitch on H in reply to Farmall Ed, 03-27-2004 18:28:00
Sounds like you don't have everything you need for a proper fix. Most cylinders use "back-up rings" on each side of the o-ring. It's just a flat nylon or plastic type ring that is cut open in one spot. It takes up space in the ring groove to keep the o-ring seated and prevents it from rolling. Take your cylinder to a hydraulic shop and they should be able to fix you up with whatever you need.
Hope this helps.
