560d won't pick up disk mower?
Brian in MO
03-28-2004 09:19:07
I have a 560 that I use to mow and bale and feed hay in the winter. I bought a used disk mower (8' cut)over the winter but the tractor won't pick up the mower. I have 3pt adapters and can pick up the whole mower just not the bar. Has anyone else tried to use one on a 560? The hydralics are good on the tractor but it just can't get enough lift with the small (special looking) cylinder on the mower.Thanks Brian
Jimmy King
03-28-2004 16:09:19
 Re: 560d won't pick up disk mower? in reply to Brian in MO, 03-28-2004 09:19:07
You need to ck. the PSI at your remote plug in, it should be about 1500 PSI
Brian in MO
03-29-2004 19:08:12
 Re: Re: 560d won't pick up disk mower? in reply to Jimmy King, 03-28-2004 16:09:19
Yea I have checked the PSI everything seeems normal. I have talked with a friend that said he was going to use his on a disk mower till he found it would not pick his up either.
r4etired
03-28-2004 17:31:12
If you need a pump email me I just bought a 560 parts tractor
Nebraska Cowman
03-28-2004 14:13:20
can you switch to a larger cylinder? I know I have had to do that on some equipment.
