Farmall M-Plug Fouled?
BB
03-28-2004 18:36:20
My M runs very well at idle, but as the trottle is increased she runs like all cylinders are not there. I pulled the plugs and they have lots of black build up. A couple of the plugs were pretty wet with gasoline also. Could this simply be a fouled plug? I just bought the tractor so I guess anything is possible. The tractor holds great oil pressure. Any trouble shooting tips would be helpful. Thanks.
Dave BN
03-28-2004 19:30:06
 Re: Farmall M-Plug Fouled? in reply to BB, 03-28-2004 18:36:20
It's sometimes hard to tell if all cylinders are firing when an engine is idling. You can pull the wires off the distributer cap or plugs one at a time and see if the engine runs any different. If you pull off a wire and it doesn't change how the engine runs, then you know that cylinder wasn't firing. I use pliers with insulated handles as I have been kicked before doing this. I also would try 4 new plugs, maybe distributer cap and rotor also depending on how the old ones look. Maybe plug wires also. Those parts aren't too expensive and then you'll at least know those parts are good.
Good luck. Dave.
Hermit
03-28-2004 19:07:26
Sounds like the carburetor is adjusted too rich on the main jet.
gene b
03-28-2004 19:06:56
I would put in 4 new ones and then take a look aand see how clean they run. Would not hurt to go a step hotter.
fred
03-29-2004 04:15:20
 Re: Re: Farmall M-Plug Fouled? in reply to gene b, 03-28-2004 19:06:56
try new plugs try a set of motor craft they are better than champion or ac and try setting carb also check wires and cap
Rich Cota
03-29-2004 04:14:35
Your carberator is set too rich. Turn the power adjust screw (on the bottom pointing towards the radiator)all the way in, then turn out 2 and 3/4 turns. That should do it.
