H transmission oil
Matt in Tx.
03-29-2004 06:28:41
I recently bought an old H at auction and am tinkering with it from time to time on a gradual path to restoration. The gearbox had alot of water and sludge in it so I drained it and flushed it with diesel a couple of times. My question is: Since the diesel ran out of both axle seals and the input seal, am I probably going to need to replace those, is the gear oil thats supposed to be there thick enough, and is the oil level supposed to be up to the axles, and if not, how much. Thanks.. matt
Theman
03-29-2004 08:16:45
 Re: H transmission oil in reply to Matt in Tx., 03-29-2004 06:28:41
There is a pipe plug on the side of the transmission near the clutch pedal pivot. Fill until oil just starts to apear at the bottom of the threads. Keep in mind that there are two drain plugs for the transmission. One is at the front of the transmission and the other at the back below the PTO shaft. Make sure all of the diesel is drained before adding a drop. Also -please, please, please get an operators manual at your first opportunity. There is a lot of good information in it for properly maintaining your H.
