Help identify M carb
MM
03-29-2004 12:19:11
third party image
Can anyone help specify which kit to get for this M carb. Tractor serial is #22402(1940). Block has 2-25-O(1945). Carb upper casting has 6513 D on it. It doesn't have a tag with a number on it. Where would I find # on it?
Thanks for any help
Theman
03-30-2004 07:11:50
 Re: Help identify M carb in reply to MM, 03-29-2004 12:19:11
The ID tag is a little brass ring the size of a #6 flat washer. It is held to the carburetor housing by a rivet through its center. It is visible in your photo between and slightly to the right of the idle mixture and speed adjusting screws. Being brass, don't use a screwdriver to scrape the paint off of it. You could render the stamped numbers unreadable. I have had success removing the paint by soaking part of a paper towel with carb cleaner and dissolving the paint over the tag. Rub gently and use latex gloves.
MM
03-30-2004 08:36:00
 Re: Re: Help identify M carb in reply to Theman, 03-30-2004 07:11:50
Thanks very much
Delbert
03-29-2004 16:57:56
There is a little brass ring on it somewhere that gives you the i d no.
