Order Farmall Cub Parts Online
cub block plugs
Mike(IL)
03-29-2004 19:04:16
i have taken a part a cub engine to rebuild. new bearings, rings and gaskets etc. After a good cleaning in and out i am now putting it back together, and i noticed that i have an extra plug and i don't see where it goes. the parts book says qty 5. i have found the following ones,1 on top of the block by the oil filter cap,1 on the left side just below the tappet cover,1 to the left rear of the engine where the oil pump can be primed, and 1 in the main oil passage in the rear of the valve lifters( inside the cover). Where is the fifth one? what am i missing? Thanks for your help
Mike
Wardner
03-29-2004 21:20:57
 Re: cub block plugs in reply to Mike(IL), 03-29-2004 19:04:16
Isn't there one behind the cam gear? The one most people forget is the one directly behind where the carb is located (tappet chanber).
Good call on your part for noticing the extra plug. An engine rebuilder would probably throw it away. It happened to me. If you still can't find it, put in the crank, camshaft, oil filter and apply compressed air or pressurized oil to the oil gallery.
