Order Farmall Cub Parts Online
1948 Cub need distributor
L. Miller
03-30-2004 11:04:38
1948 Cub has J4 magneto and I need to find the best type/model distributor to replace it with.
Any help would be appreciated. Thanks!
49 Cubber!
03-30-2004 14:39:45
 Re: 1948 Cub need distributor in reply to L. Miller, 03-30-2004 11:04:38
Call a salvage yard!atis.net has a state by state list!
Bigdog
03-30-2004 11:47:53
Unless you don't like the appearance, you can add an external coil to the mag setup and rewire it using the mag distributor with the coil. Just run a hot lead through a switch to the coil and from the coil to the kill terminal on the side of the mag distributor.
John *.?-!.* cub owner
03-30-2004 12:24:09
 Re: Re: 1948 Cub need distributor in reply to Bigdog, 03-30-2004 11:47:53
Don't forget to disconnect the internal wire from the points to the mag coil. You only get one guess as to why I remeber that.
