Farmall H bolster bushings
Ken
03-30-2004 14:45:59
Has anyone replaced the lower bushing and bearing in the upper bolster? If so does the stem and associated parts go in as a unit or does it go in a seperate pieces? Seal ring/bearing/bushing/steering stem. And also whats the easiest?
john d
03-30-2004 18:22:41
 Re: Farmall H bolster bushings in reply to Ken , 03-30-2004 14:45:59
It's not a tough job, really. Bob M's pictures will help you quite a bit. Block the tractor so it CAN NOT ROLL OR DROP! Don't get in a big hurry. If something doesn't want to go back together, don't reach for the big hammer as a first response. On the other hand you may well need the BIG hammer to get the shaft to drop out of the sector gear after you take the nut off the top. If you have to hit it, put an oak block or a piece of aluminum on top of the shaft so you don't mess up the end of it. Keep your toes back when it drops.
Bob M
03-30-2004 17:11:12
Ken - Punch below for several pix taken as I rebushed the bolster on my Super H - may help answer some of your questions. ...Bob M
r4etired
03-30-2004 16:25:38
In the bottom of the bolster there is a thrust bearing,a thrust plate. a sleeve bushing and a felt. It,s been a long time ago I redid mine. I didn,t think it was a bad job. Local dealer got all the parts for me
