h running rough
scott
03-31-2004 06:18:43
when i start the h it runs rough. It doesnt seem to be firing on cylinder 2 and 3. I just rebuilt the carb. Could there be a problem with it. I do have spark on all 4 cylinders
Bob in SE Nebraska
03-31-2004 14:03:08
 Re: h running rough in reply to scott, 03-31-2004 06:18:43
I have had similar problems and found out the the valves were out of adjustment. It's not a very hard thing to check and sure can solve the problem if they are out of adjustment.
Bob
old
03-31-2004 08:22:57
It could be as Rusty says or you may need to do a good tune up points, plugs cap and rotor any one of them could be the problem.
rustyfarmall
03-31-2004 07:42:19
You may have the carb set too lean, richen it up a bit and see if it doesn't smooth out.
