Help! Can't keep front wheels on ground W/3414 lo
mike
03-31-2004 14:42:15
Hi, I have a 66 model 3414 loader backhoe. The problem is is that I can't keep the front wheels down if on any sort of grade. There are weights attached to the front below radiator. The hoe is a 3131 which I know is heavy in the rear but I need some suggestions. I was going up a logging road with only a minor grade and the front was airborne the entire time-scary. Also what can I do about the brakes! The Flintstones could stop better than I can!!!! Thanks Mike
Wardner
03-31-2004 14:48:29
 Re: Help! Can't keep front wheels on ground W/341 in reply to mike, 03-31-2004 14:42:15
1. Put some dirt in the loader bucket.
2. Make sure hoe is fully folded and secured in travel position.
3. Don't go out on the highway until it is stable.
