smta belt pully leak
paul
03-31-2004 17:43:48
My belt pully drive housing leaks fluid where the belt pully bolts onto the housing.No help from manual is there a seal in there or just shims? Thanks Paul.
TDK
04-01-2004 12:44:09
 Re: smta belt pully leak in reply to paul, 03-31-2004 17:43:48
Paul, I believe Randy is right. I rebuilt the unit on my M, but removed complete unit because of leak between unit and trans. Remove the 3 bolts from bearing cage behind pulley mounting flange on shaft. Use a slide hammer fastened to pulley shaft to remove the shaft. With shaft out, remove gear,brg.,spacer from shaft. Bearing cage will then slide off of shaft. A snap-ring holds brg. in cage, remove ring and brg. & you can then get seal out. While replacing seal it's a good idea to replace felt washer too. Hope this helps.
Randy SE-MN
04-01-2004 09:30:36
Paul...I believe that it will come all the way out without removing the whole power unit. It does take a slide hammer though. Anyone correct me if I'm wrong.
TDK
03-31-2004 18:19:58
There's a seal,as well as shims. Gearbox has to be taken apart to change it.
paul
03-31-2004 18:33:02
 Re: Re: smta belt pully leak in reply to TDK, 03-31-2004 18:19:58
Do you have to remove the gearbox or can you get to the seal by removing the end cap looks like about 4 or 5 bolts?
