IH 454 electric fuel pump
Joe
03-31-2004 17:45:07
Did the 454's come with electric or manual fuel pumps? The IT manual I have shows a manual pump but I've got an electric. Anyhow... The tractor has been sitting for a year or so without running. I've got the tractor to where it will crank and cough but it is flooding the carb. I read in the archives the float/seat/and needle valve are probably bad. What keeps the electric pump from over pressurizing the carb and blowing past? Should their be a regulator or return line? Thanks!
Bob
03-31-2004 18:40:03
 Re: IH 454 electric fuel pump in reply to Joe, 03-31-2004 17:45:07
If you are talking about a small, pulse-type electric fuel pump, they are self-limiting to a specific pressue, usually between 2 and 8 psi, depending on model number.
If you are talking about a vane or gerotor type pump, as is used in racing or fuel injection applications, these normally need a separate regulator.
Joe
04-01-2004 04:22:19
 Re: Re: IH 454 electric fuel pump in reply to Bob, 03-31-2004 18:40:03
I'd say it the pulse type fuel pump. It's worn and the numbers are no longer visible. When running it sounds like it's pulsing. So it's probably carb rebuild time? Thanks!
