Re: 1949 Farmall M hydraulic questions
jamie ivester
03-31-2004 19:36:05
checked it out today, the hyd line isn't live, but there are two capped elbows coming off the left hand side of the tractor... any ideas?
NDS
04-01-2004 05:28:42
 Re: Re: 1949 Farmall M hydraulic questions in reply to jamie ivester, 03-31-2004 19:36:05
That sounds like standard belly pump. Should be one outlet on right side also. I run my Saginaw directly off one of these outlets. To do initial check simply pull back lever that goes to arm in this area on right side. With tractor running at idle in neutral clutch out you should hear motor load up if pump is working. Might be good idea to remove 1/2 inch plug in casting that drops down under tractor in this area drain oil and add 6 qts. non detergent 30 W oil through 1 inch pipe that sticks up through top.
