Power steering plug in Hydratouch valve.
John Humphrey M
03-31-2004 22:23:09
I have gathered almost all the parts to install power steering on my Farmall 400. I am missing the lift circuit block plug which blocks the flow of oil into the left hand Hydratouch from the Hydratouch control valve column. Does anyone have one of these or the dimensions so that I can turn one on the lathe? Thanks to anyone that can help. John Humphrey
Dave W V
04-01-2004 05:33:25
 Re: Power steering plug in Hydratouch valve. in reply to John Humphrey Morocco IN., 03-31-2004 22:23:09
John a sunken head 1/4 pipe plug will work.Tap
hole make sure metal chips are cleaned out and plug is screwed in enough for valve to clear.If you would rather use stock plug i could go measure one and let you know.
04-01-2004 10:52:01
 Re: Re: Power steering plug in Hydratouch valve. in reply to Dave W V, 04-01-2004 05:33:25
Dave; Thank so very much for taking the time to get the numbers for me. I will knock one out on the lathe first chance I get. Again; THANK YOU John Humphrey
04-01-2004 05:47:24
I was wanting to do it the OEM way, not that the rest of the tractor is stock or restored> Any help would be really appreciated. Thank you; John Humphrey
Dave W V
04-01-2004 07:21:13
 Re: Re: Re: Power steering plug in Hydratouch valv in reply to John Humphrey Morocco IN., 04-01-2004 05:47:24
John plug is only 1/2 inch long and has 3 od diameters counting o ring grove.largest dia. is
.625 and .080 wide,main dia. .495 , .420 wide.O ring grove is in center of .420 width,it is .075
wide and dia. at bottom of grove is .400 . Hope this is understandable.
Dave W V
04-01-2004 06:18:14
Will measure and post results.
